Downconvert VI Requests
Thanks a lot.  The downconvert works fine.
DAve
Message 1141 of 1,444
(1,415 Views)
@averagejoe wrote:
added only one file above here are the rest. in these zip folders. i need all of them downconverted from labview 2011 to labview 7
thanks
See attached. I actually started with the 8.0 versions of these drivers from IDNET. Less work.
Message 1142 of 1,444
(1,410 Views)
I need to convert a DS335 instrument driver from version 8.0 to 6.0.  Thanks in advance for any help!
Message 1143 of 1,444
(1,402 Views)
try the attached
Message 1144 of 1,444
(1,396 Views)
thanks for doing that. heres a question if you can downconvert can you up convert to. if i need a 7 programme converted to 11 can you do that
Message 1145 of 1,444
(1,387 Views)
Hi Joe,
1) there's a thread dedicated to upconversion...
2) Can't you load LV7 VIs directly in LV2011?
Message 1146 of 1,444
(1,384 Views)
can you please convert these two files from 2011 to labvie 7
thanks
Message 1147 of 1,444
(1,381 Views)
I'd like to have these vi downconverted from v9.0 to v8.5 if you please!
Thanks!
Message 1148 of 1,444
(1,376 Views)
thanks
Those 2 VIs aren't going to do you any good since they use subVIs from the project library. I used the 8.0 drivers to downconvert to 7.0, since it's a lot of work to downconvert project libraries all the way down to LabVIEW 7. There should be equivalent VIs in that driver set.
Message 1149 of 1,444
(1,367 Views)
Thanks!
Was only able to downconvert 2 of them. The other kept crashing LabVIEW, and I even tried LV 2011. Maybe someone else might have better luck.
Message 1150 of 1,444
(1,365 Views)
