Downconvert VI Requests
@kpele wrote:
Would someone be able to convert this vi from 2011 to 2009 please?
The subVI "SubOutsideTemp" appears to be corrupt. I was unable to open it at all, having received a LabVIEW "Generic Error" "Cannot load front panel".
Message 1311 of 1,444
(1,710 Views)
@fishingman wrote:
Please smercurio_fc convert me this VI. My problem is i have many VI with differents version of Labview(Drivers for materiels) and i need to use Labview 6.0.
Thanks Very Match
You'll need a replacement for "Trim Whitespace" and the space constant. The first can be written quite easily. The second is just a string constant.
Message 1312 of 1,444
(1,710 Views)
acfkt,
Here ya go.
Daniel
Message 1313 of 1,444
(1,706 Views)
Hi everybody, I need to convert a file created in a 4.1 version to a 8.5 version of LabView. Can you help me please?
Message 1314 of 1,444
(1,703 Views)
Can I please get a downconvert from labview 2010 to 2009 ?
Message 1315 of 1,444
(1,694 Views)
Posting again the project to convert from 9.0 to 8.5. Hope it will be possible now.
Thanks.
Bim
Message 1316 of 1,444
(1,686 Views)
Hi bim,
what has changed since yesterday? Neither your zip nor LabVIEW has changed since then!
Still it crashes on downconversion of the ZLIB-VIs...
Message 1317 of 1,444
(1,683 Views)
First, this thread is for downconversions - to go from a higher version of LabVIEW down to a lower version of LabVIEW. You should have posted in the Upconvert Requests Thread, which goes from a lower version of LabVIEW up to a higher version of LabVIEW. Down. Up. Simple, right?
Second, the VIs were saved without a block diagram. They cannot be converted.
Message 1318 of 1,444
(1,672 Views)
Polite 'bump' of this post. I have a feeling it may have got lost amongst some of the other requests.
Version 8.6 down to version 8.5
Apologies for my impatience!! Smiley Wink
Ian
Message 1319 of 1,444
(1,671 Views)
Ian
I had actually tried to do that. LabVIEW kept crashing. It typically does that when dealing with CLFNs. Tried 2009, 2010, and 2011. All of them crashed. Sorry.
Message 1320 of 1,444
(1,662 Views)
