Double digit display of one digit number
Hi all,
I was wondering if there is a quick way of showing one digit numbers between 0-9 as in 00-09.
Best,
Kutal.
(5,224 Views)
Accepted by topic author serkut17
Display Format of your numeric indicator.  Right click and go to properties, choose the Display Format tab.  Choose the Floating Point, with minimum field width of 2, and Pad with zeros on the left.  Then in Data Entry tab choose the range to be from 0 to 9 with coerce if outside that range, and increment of 1.0 if you are using a double.
(5,220 Views)
Thanks a lot for the message, do you have an idea to convert this two digit numbers to string without losing precision
(5,160 Views)
Format into String.
(5,149 Views)
i tried but it eliminated the leftmost integer
(5,147 Views)
Did you set the format string code properly?
Right click on the function and select Edit Format String.
Spoiler
%02d
(5,141 Views)
Just as RavensFan suggested 😛 Check the image below, if still nor clear.
uday
(5,122 Views)
