Does the 3dpc line plot have a memory leak? (ver 8.6.1)
I have a very large application with a very small memory leak and the 3dpc line plot appears to be the most likely candidate.
I create a line plot of data (100-200 points of XYZ) pass this to a Create 3dpc_surfaceplot:xctlcreate.vi in a loop (updated at a few hz).
This code appears to grow in memory slowly over time (not at a regular pace sometimes a garbage collector must kick in).  Is this possible, is there anything I have to do to use this function in a loop, there is no help file provided for this vi.
Can I avoide this situation (I am having trouble replicating te out of memory my client is seeing but again this is the most likely cause)?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,599 Views)
Hi Paul,
Thank you for bring this to our attention. Do you have a small piece of code that exhibits this memory leak? If so, can you please it so that I can try to reproduce the issue here? If I can, then I can report the issue to R&D for further investigation.
Aaron P
http://www.ni.com/support
(2,584 Views)
