Does somebody have a vi that send an arry to NI 6731
I want to send an arbitrary wafeform of 1000000 points to channel 0, with a sampling rate of 2000s/sec, using FIFO or PC memory.
(2,541 Views)
Greetings,
This is extremely easy to do in the LabVIEW environment. If you have LabVIEW, please open the example finder by going to Help->Find Examples. There are a number of examples that ship with LabVIEW which perform analog output with the 6731 board. Try the Getting Started with Analog Output example. You can also find this example online at the following address.
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E33556A4E034080020E74861&p_node=200083&p_submitted=N&p_rank=&p_answer=&p_source=Internal
Justin Britten
Applications Engineer
(2,541 Views)
