Does importing MAX config settings file replace or append the existing MAX entries?
Does importing a .nce file into max replace the existing config of max with the imported config, or does importing add the new MAX items to the existing MAX items (so that both the "old" and "newly imported" config can be used.
(3,437 Views)
Accepted by topic author chassan
Either or both! (sometimes neither):smileysad:
in the import wizard you can select which items to import and what to do about items that conflict or exist with different information.  (NI really did a nice job - for NI devices!)  for some things (like Pickering VXI devices) you can't import the MAX settings.
"Should be" isn't "Is" -Jay
(3,434 Views)
Jeff,
Thank you for the good information.
Chris
(3,429 Views)
Glad to help!
(3,425 Views)
