Taking Automatic Oscilloscope Screenshots
Using labview signal express, I can click "take screenshot" and I get exactly what I need (namely, a very long CSV file showing the signal on each channel).  Thing is, I have to manually click "take screenshot" for every screenshot I get, which is to say thousands of times!  Is there a way I can automate this process? Please be specific, I am not an engineer.
Scope: Tektronix TDS 1012B
Computer: Windows 7
Thanks!
(3,121 Views)
If you are looking to move to LabVIEW, the answer is yes. If you want to stick with SignalExpress, post your question to that board.
(3,107 Views)
Maybe you can get the visible portion of the Oscilloscope VI as an image and save that programmatically from a timed loop in another VI.  The visible portion image is a property of the VI, but I can't remember specific 'syntax' that was used.
(2,917 Views)
