Does anyone have an indicator that works like a compass??
I'm looking for an indicator that will show compass heading. The gauge indicator has zero at the bottom instead of the top. Thanks in advance.
ssmith@bnl.gov
(9,374 Views)
You can grab the markers on the dial and drag them around the edge to orient them where you want them. You can also set them with a property node. This will give you a fixed dial scale, with a needle pointing the heading. See the attached. Hope I've understood your question.
Matt
(9,374 Views)
Next,
pop-up and choose
properties >>> Text labels
Check "use text labels for scale markers"
Un-check "sequential values"
then enter;
0 ->
90 -> E
180 -> S
270 -> W
360 -> N
and you have a good old fashioned compass. See attched image.
Ben
(9,374 Views)
Cool! Thanks Ben.
Matt
(9,375 Views)
Matt--
Thanks a lot for the help.
ssmith
(9,374 Views)
This was VERY helpful for me. But here is some info to clarify a bit.
Go into Properties. Change the scale to 0 min and 360 max. Exit properties.
Move cursor over the Zero. It will change. Now click/drag the zero to the top. Move cursor to 360 and click/drag it over the Zero.
Go back into Properties and follow Ben's advise about the text labels
Good Luck
(8,186 Views)
