取消
显示结果
搜索替代
您的意思是:
Do the Tektronix driver subVIs have similar funcitions and connector panes as that of the Le Croy oscilloscope?
Hey everyone,
0 项奖励
1 条消息(共 8 条)
3,189 次查看
Best scenario would be the set of IEEE488.2 functions, which are limited compared to the "extensions" most manufacturers add.  I believe Tektronix drivers follow the standard. Never heard of LeCroy.
2 条消息(共 8 条)
3,186 次查看
@Queen wrote:
Hey everyone,
You can find out by downloading both drivers and LOOKING.
This thread is a continuation of one started by the OP earlier  http://forums.ni.com/t5/LabVIEW/Labview-conversion-from-Le-croy-to-tektronix-Oscilloscope/m-p/223040...
0 项奖励
3 条消息(共 8 条)
3,159 次查看
Thanks Bill, that is probably the most helpful reply so far!
0 项奖励
4 条消息(共 8 条)
3,155 次查看
nyc, if you have no helpful reply please stay away from my threads!
0 项奖励
5 条消息(共 8 条)
3,154 次查看
Have you even looked at the driver VIs for both scopes?????
I don't understand how you expect to accomplish anything by just "talking" about something.
0 项奖励
6 条消息(共 8 条)
3,145 次查看
I am in the process of doing so! again you're not helping by being aggressive...I really I don't understand what problem you have but you need to work on your replies!
0 项奖励
7 条消息(共 8 条)
3,140 次查看
I don't have a "problem".
What is important for you to understand is that this is not a trivial task.
You write as if you expect it to be such.
Asking what is essentially the same question twice does you no favors.
0 项奖励
8 条消息(共 8 条)
3,137 次查看
