Do i have to manually close this reference?
i have a cluster of references where i use unbundle to get the needed reference and then "Propery: Value" to set the value.
Do i have to close the reference after this action? Does it need memory when not closed?
Or is this automatically done?
Thanks for help
(3,172 Views)
Hey
Check out this thread here
Sletten
(3,149 Views)
The recommended practice is to close all references in order to avoid memory leaks.
Ben explained the following:
"Repeatedly opening and closing ref's will eat up memory because there are resource allocated for each open. The close does not delete these resource (memory) but only marks them as available for deletion. The clean-up only happens when the VI goes idle (ie: stops running gracefully)."
(3,133 Views)
You never need to close control references...they'll be cleaned up by LabVIEW when your VI goes idle.
(3,092 Views)
Would that be acceptable in a CLD exam?  😉
(3,082 Views)
If I were grading a CLD, I would not take off for unclosed control references.  Then again, I've never graded a certification exam.  🙂
I'll relay my feedback to the certification team that control references need not be closed.
(3,062 Views)
Thanks Darren 🙂
(3,044 Views)
