Do Modbus drivers exist for LabVIEW 8.0?
I have LabVIEW 7.1 on an existing computer and I was able to get ModBus drivers for it.  I have another pc with 8.0 only and I tried installing the drivers.  It tells me that 7.1 is needed.  Has there been an update to these drivers?
Thanks in advance.
Ron Deavers, CLD
(2,785 Views)
If you have the DSC module, then you should already have some Modbus support there. If you don't, you can search the forums. The VIs you are refering to can only be installed on a PC with LV 7.1, but they will work on other versions as well and they have already been posted to the forum before saved for 7.0 and 8.0.
___________________
Try to take over the world!
(2,775 Views)
