Dll Register server not found
I tried to incorporate Labview DLL on the VB6.0 Project, but i encountered the following errors:
1. when I register is on RGSVR32, it has an error "DLL Register Server entry point not found"
2. I tried to declare it in VB with the arguements based on the H file. But when I
it run the routine it has same error appearLL Register Server entry point not found
Pls advice
(3,939 Views)
While I never used a Labview DLL in a VB6 project, I know that a LV DLL, unlike a VB6 DLL, doesn't have a COM interface and therefore must not be registered.
What you need to do is rather like calling a VC++ DLL, using the Declare statement with the Lib specifier.
Paolo
(3,925 Views)
Thanks for the reply..
Can you help provide specific example.
thanks
(3,891 Views)
By searching        Labview shared DLL Visual Basic      into NI's site Support, you can find the following:
http://zone.ni.com/devzone/cda/epd/p/id/2714
http://zone.ni.com/devzone/cda/tut/p/id/3188
and nested links.
Paolo
(3,870 Views)
