Divide 2d array row- wise and display frames
Hello everybody,
For using in image construction, I need to divide a large 2D array into groups of rows and show one block at a time.
As an example;
In attached .vi, I get only the last 2 rows and can not see any intermediate step.
How can I display these steps?
Any other idea for dividing the array?
Thanks in advance,
Mittani
(4,219 Views)
I think you may want to wire your index and length to "i" not "N".  Doing this causes the length of the subarray to vary also.
You do not need the sequence structure or the local variable.  Just use a wire.
Lynn
(4,215 Views)
How can I keep the size of the sub array constant?
The subarray should contain only two rows. In this case the subarray size increases and in the end becomes equal to the source array.
Mittani
(4,204 Views)
Accepted by Mittani HD
By wiring a constant to the size terminal, maybe? Seems obvious! 😄
(4,198 Views)
Yes, you are is rigt:)
Thanks a lot.
(4,191 Views)
