Display more functions in functions pallete
I am working with labview 8. I used to use a function called read characters from file .vi     in labview 7.  I see that it is still in the labview 8 vi.lib  but it does not show up anymore in the function pallete. How can i make it so that it is included? I know some array functions i used to use are also missing from the pallete.
(3,283 Views)
It's been replaced by Read from Text File. This works the same way, except you can move the file pointer to specify where to start reading.
You can edit the palette by going to tools -> advanced -> edit palette set... I haven't tried to add VIs from vi.lib, or from an llb for that matter, so I don't know if you'll be able to do it.
(3,275 Views)
Actually i need the write characters to file. It has an append option, where i dont see it on the write text to file ect...
Anyways, you can add librarys, so i added the file.lib to the pallete.
Thanks for the help.
Message Edited by dirtyb15 on 02-01-2007 02:18 PM
(3,272 Views)
If you usen VIPM and download the OpenG packages, you'll see a dynamic palette package, this includes a .mnu file of the 7.x palette
Ton
My LabVIEW Ideas
(3,265 Views)
Just so you know, you can still append to file using the new VI. In the advanced file functions palette there are VIs to move the file pointer for random access to a file. Use Set File Position and change the "from" input to "end." This will move the pointer to the end, then use write text to file and it will append. It might seem like a little more work, but doing this will let you keep the file open and write to the end of it multiple times whereas the old write characters vi opened and closed the file each time.
(3,255 Views)
Didnt know that, ill have to try that.
Thanks!
(3,252 Views)
