Display maximum value
Hi! I have a program connected to a database. It reads the database and displays the contents in a table and in a graph. The point is that I want the maximum value obtained on each day to appear on the graph. Can you help me?
Inês
Message 1 of 8
(3,605 Views)
Hi inescruz,
Read the data for "each day" from your database, then determine the max value.
Put those max values in an additional plot of your graph…
Message 2 of 8
(3,599 Views)
Hi GerdW,
I have the data organized in this way in the database. I want the program to get the maximum value for the different days. Then I want the value and the respective date to appear on the graph.
Message 3 of 8
(3,588 Views)
Hi inescruz,
Use a loop to iterate over your days:
  • Then read data from your database by selecting the data for one day.
  • Get the maximum of the data of that day.
There surely is a "SELECT" command suitable for your database…
Message 4 of 8
(3,569 Views)
Hi GerdW,
Can you explain to me how I can do this iteration, please?
Inês
Message 5 of 8
(3,239 Views)
Something like this:
SELECT MAX(column) from TABLE where date=....
https://www.w3schools.com/sql/sql_min_max.asp
If you dig further you can probably create a SELECT command, that gives you the MAX value for each day of e.g. one month.
Regards, Jens
Kudos are welcome...
Message 6 of 8
(3,237 Views)
Google "query maximum per day"
For instance: sql server - SQL query to get maximum value for each day - Stack Overflow
It will depend on the database. SQLServer SQL isn't Access SQL.
If you want a specific day (or if you know all days from a previous query), you can do something like:
SELECT TOP 1 value FROM data WHERE date>start AND date<end ORDER BY date DESC
Each part of this query is highly googleable.
There's also the max clause:
SELECT max( value ) FROM data WHERE ...
Again, google is your friend here.
Message 7 of 8
(3,207 Views)
Hi JensG69,
I changed my block diagram and put up a dial that says what the maximum force was. Through the table, can I ask the labview to read it and tell me what is the maximum value for each day and show those values in a graph?
Regards, Inês
Message 8 of 8
(3,066 Views)
