Display image on extended desktop monitor
I am using a high resolution monitor from Double Black Imaging as an extended display.
I would like to display an image on this extended monitor and open and close it with the desktop monitor through LabView.
Any suggestions?
-Venkat
(3,262 Views)
Hi, Venkat.
There's no VI that does that in LabVIEW, but it sounds like something you could do with the Windows API. I recommend searching on MSDN.com.
Good luck!
Sarah K.
Search PME
(3,253 Views)
If this display is used as a second display through windows (so you can move your mouse from one to the other), it's not that difficult.
With an Application Node "Display>All Monitors" you get a list of all monitors and there resolution. Now you have to make a vi that puts it's front panel to the size of the monitor you want to use. On the front panel you put the picture you want.
Hope it helps.
Wiebe.
"VIYER" <x@no.email> wrote in message news:1150945806957-381932@exchange.ni.com...
I am using a&nbsp;high resolution monitor from Double Black Imaging as an extended&nbsp;display.
&nbsp;
I would like to display an image on this extended monitor&nbsp;and&nbsp;open and close&nbsp;it with the desktop monitor through LabView.
&nbsp;
Any suggestions?
&nbsp;
-Venkat
(3,249 Views)
