Display image on extended desktop monitor
I am using a high resolution monitor from Double Black Imaging as an extended display.
I would like to display an image on this extended monitor and open and close it with the desktop monitor through LabView.
Any suggestions?
-Venkat
(3,116 Views)
Hi, Venkat.
There's no VI that does that in LabVIEW, but it sounds like something you could do with the Windows API. I recommend searching on MSDN.com, and this KnowledgeBase has more information on using the Windows API with LabVIEW.
Good luck!
Sarah K.
Search PME
(3,107 Views)
If this display is used as a second display through windows (so you can move your mouse from one to the other), it's not that difficult.
With an Application Node "Display>All Monitors" you get a list of all monitors and there resolution. Now you have to make a vi that puts it's front panel to the size of the monitor you want to use. On the front panel you put the picture you want.
Hope it helps.
Wiebe.
"VIYER" <x@no.email> wrote in message news:1150945806957-381932@exchange.ni.com...
I am using a&nbsp;high resolution monitor from Double Black Imaging as an extended&nbsp;display.
&nbsp;
I would like to display an image on this extended monitor&nbsp;and&nbsp;open and close&nbsp;it with the desktop monitor through LabView.
&nbsp;
Any suggestions?
&nbsp;
-Venkat
(3,103 Views)
