Display Options Locked
I want to change the Front Panel options to make it look better, but the change i make in the options doesn't do anything.
For example, I choose "Control style for new VI's -> System", I will still get default controls, even with new VI's.
If you know what is happening and can help me, thanks by advance.
(2,353 Views)
Accepted by Julien.K
Hi Julien,
  • Existing VIs will not be changed when changing this specific option.
  • New VIs should use the "System" controls - as long as there are existing System controls for that specific control/indicator! (There are no charts/graphs, no VISA references, no colorboxes, …)
What else do you want to change?
(2,349 Views)
You already got a good answer, but please clarify what you mean by ""default controls" and how you "get" them?
For example if you right-click on a connector of a placed subVI and "create control/indicator", you typically get the same style as in the subVI, overriding your defaults.
Here I made a very simple subVI that had a modern scalar as input and output. Then I edited the subVI and replaced the control with a system numeric and the indicator with a modern chart.
If I place this subVI in a new VI and do a create/control/indicator, I get exactly what the subVI has. This is a great feature! I actually use it to my advantage, carefully selecting front panel elements in style and labeling for all my custom subVIs. 😄
(2,307 Views)
Personally, I would recommend not to use system controls as defaults. They inherit a lot of things from the OS theme and e.g. some buttons will look quite different if you compare the same front panel in windows 7 vs. windows 10 (no longer a really big problem since windows 7 is no longer supported as of LabVIEW 2021, but you get the idea). System controls also have very limited customization and a user that uses a really ugly windows theme will get an ugly front panel to match, no matter how good it looked during your development. Too many unpredictables!
Have a look at some of "frameless" silver controls as clean alternatives.
(2,305 Views)
Thank you all for your answers !
I never thought such a basic question would get so much.
I managed to set the "system" skin as default accidentally, so I guess everything is solved. 🙂
Enjour your Christmas Eve.
(2,282 Views)
