Display Gray Scale Image
Dear  Members,
Kindly, how can I display (write) a gray scale image in labview using Flatten Pixmap when my input image is a two dimensional matrix 64x64 gray scale.?
Message 1 of 12
(7,514 Views)
Accepted by topic author Tasnim
One way of doing it would be to wire an array representing a greyscale colour map to the colors input of Flatten Pixmap.vi.
Message 2 of 12
(7,490 Views)
Thank you very much for the useful answer..
in case I want to read a gray scale image in labview using Flatten Pixmap.vi or Unflatten Pixmap.vi when my input image is a two dimensional matrix 64x64 gray scale..is it the same way you answered me before?
Thank you
Message 3 of 12
(7,459 Views)
If you want to read data from an image that is a 2D Picture Control, use Picture to Pixmap.vi then Unflatten Pixmap.vi to return a 2D array.  If your data is in the form of a LabVIEW matrix, it will have to be converted to a 2D array first as the picture functions do not operate on matrix data.
Andy
Message 4 of 12
(7,444 Views)
Thank you Andy for the useful answer
Message 5 of 12
(7,398 Views)
Dear Members,
Can anybody advise me how to display grayscale (.tiff) image size of 64x64 and the image depth is 8 in LabVIEW?
Thank you
Tasnim
Message 6 of 12
(7,356 Views)
Tasnim,
Just to check: do you mean read an existing TIFF file and display it in a picture control in LabVIEW?
Andy
Message 7 of 12
(7,351 Views)
yes, this is what I mean.
Thank you
Message 8 of 12
(7,334 Views)
I don't think LabVIEW has anything built-in to read TIFF files directly.  Many posts discuss use of the IMAQ image library or libtiff.
This post has a library which might help you, and there are a few threads on lavag.org discussing reading of TIFF files.
The easiest thing to do might be to convert losslessly to a suitable format that LabVIEW can handle using an external tool, but I have no experience of this.
Andy
Message 9 of 12
(7,322 Views)
ok thank u very much for the reply and help..
I will try to check it
Message 10 of 12
(7,306 Views)
