Display 1-bit Depth BMP file in LabVIEW
I'm trying to read a 1-bit depth BMP file into LabVIEW, but using the 2D Picture Control it keeps on coming out black.  It opens fine in Paint/PhotoImpact applications and I can see the image as a boolean array (1-bit pixmap) using the code below - so how can I display the actual BMP image using LabVIEW?  NOTE: The attached ZIP file contains the offending BMP image - not allowed to attach BMP files directly - thtat's odd?
Message 1 of 8
(5,851 Views)
Accepted by topic author ChrisReed
Your colors are not RGB, but 32 bit. White is defined as xFF000000 instead of x000000 and black is defined as 0xFFFFFFFF instead of 0xFFFFFF.
If you rewrite to colormap correctly, the image looks OK, see attached modification (LabVIEW 2010). I don't know enough about all this to decide if it is a bug or not.
Message 2 of 8
(5,847 Views)
Top marks Altenbach - and so quick - you are a Knight of the 1st Order - thanks
Chris
Message 3 of 8
(5,837 Views)
Here's a more generic solution, simply ignoring the upper octet.
Message 4 of 8
(5,834 Views)
It is tricky since the fourth byte of the RGBQUAD struct is supposed to be 0.  Two places to assign blame here IMO, the program which generated this file should not have written 0xFF into that byte and LV should not put any value into that byte except for 0x00.
If I were NI, I would change the Read BMP Header Info.vi to put a 0x00 into that spot instead of whatever happens to be read since it is such a simple change.  In the meantime use the workaround.  Next I would probably take a look at the program used to generate this particular BMP file since it seems to be straying from the specification.
Message 5 of 8
(5,800 Views)
Hi Darin,
The image was generated from the Brother SDK for creating labels on their range of Brother P-Touch Printers.
I will send them a gentle reminder that perhaps they should check their Export Image Method - thanks.
Chris
Message 6 of 8
(5,790 Views)
Hey, I have a project, in which your program seem to be part of it, but the problem is that i want take a picture from a camera, and process it to a 1-bit matrix, in which white would represent light/low contrast colors and black dark/high contrast colors. I hope u can help me soon, any ideas are welcomed.
Message 7 of 8
(5,699 Views)
This is a long thread already marked as solved. Which "program" is part of your project? Be more specific!
I think you should start a new thread with your new question.
Message 8 of 8
(5,697 Views)
