Disabling an element of an array of a control?
I'm not that good at Labview, so this may seem like a basic question... I'm not sure if "disabling" is a proper term, but I am trying to disable/ignore some element of the array. On the picture, the last row is greyed out to indicate that the values are not being used. If I type in a 0, it will actually set the current as zero instead of not running it at that value. I tried to right click a single element, went to Advanced -> Enabled State and selected Disabled and greyed out, but the whole array gets greyed out instead. I remember being shown how to do this before, and it seemed to be something simple (it did involve right clicking and selecting on an option), but I have seemed to forget how to do this... so far I wrote NaN but it would be nice to actually disable the element.
(3,045 Views)
Accepted by laura2018
For a 1D-Array you can: Right click -> Data Operations -> Delete Element
For a 2D-Array (as shown in your picture) you can: Right click -> Data Operations -> Delete Row     OR : Right click -> Data Operations -> Delete Column
(3,033 Views)
Yes, "disabled" is not the correct term. These are elements that are outside the data range.
Note that if you quickly go to run mode and back (ctrl+m), the right-click menu gets significantly simpler (while in run mode).
(2,984 Views)
