Disabling LabVIEW navigation dialog on exit
When exiting LabVIEW, the navigation dialog always pops up. There's the option to disable it on launch, and to make it Large or Small, but is there a way to make it not appear when quitting? It would be nice if LabVIEW simply exits when the last open VI is closed or when File>Exit is selected.
(3,342 Views)
Contact NI and ask them to add this option. To my knowledge, there is no way to change this.
I believe that the reason for this is to initiate some cleanup that is required when LabVIEW exits. One thing I am sure of is that VIs remain in memory until this dialog is closed, so its probably a way to retain these, and a cleaner way to exit and prompt for a save.
Until then....just deal with it. If it is a matter of you are running target (deployed) VIs in a development environment, and don't want the users to see LabVIEW dialogs, then you do have the option of just running in the Runtime environment. I have an article being reviewed about deploying "Loader" applications, which may be of interest to you. Let me know, and I will get you a URL for the arti
cle, or advise you on using a modified version of "File Manager.vi" to open VIs in the runtime environment.
Good luck
(3,342 Views)
Have you tried the Quit LabVIEW VI in the Functions:Application Control
palette... put it outside your main loop and wire a true boolean to it from
inside the loop... when you exit the main loop (i.e. your application)...
LabVIEW closes everything... I think it'll do what you're looking for.
Bill
Jake Stern wrote in message
news:5065000000080000007D550000-1027480788000@exchange.ni.com...
(3,342 Views)
Unfortunately, there is no way to configure LabVIEW to exit when the last VI is closed. As Labviewguru suggested, I will pass this suggestion along to R&D. The method Bill suggested is probably the best option you have right now.
Matt Kisler
(3,342 Views)
