Disable the windows key?
Task manager can easily be disabled by changing a registry value.  I also need to lock out the Windows keys.  Since NI claims that LabVIEW is Part 11 compliant, I would have assumed that this function would be standard but I digress.
I have found the registry value but for some reason, the value does not get written into the registry correctly:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,03,00,00,00,00,00,5B,E0,00,00,5C,E0,00,00,00,00
I have also tried to write the binary value (0000 0000 0000 0000 0300 0000 0000 5BE0 0000 5CE0 0000 0000) as well with no luck.
Any ideas??
Thanks all!
Message Edited by ScooterInMN on 12-17-2008 10:20 AM
(4,844 Views)
I think you have to restart windows before the change in keybord settings take place
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,828 Views)
The problem isn't the restarting of the PC.  The problem is writing the correct value to the registry.  I already have in other pieces of my code to reboot after any security change.  Check out the VI I attached.
(4,795 Views)
This web site has some info
http://msdn.microsoft.com/en-us/library/aa460734(WinEmbedded.5).aspx
It is also a lt of code examples out there for C++ and VB. Perhaps a frind of yours may write a simple dll. But I can not help you out. I have not written C code for 10 years now
(4,778 Views)
This is the article that I followed.  The problem is that I can't get LabVIEW to correctly write the value to the registry.
(4,758 Views)
What happens when you try? Is the key not written? Written but not correct? Error messages?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,730 Views)
Accepted by ScooterInMN
Thanks to you I have no windows key (until I reboot Smiley Very Happy ). Change the setting for the string const. Then you can write pure hex values. Go to the msdn web site and cut and paste the values .Worked for me. Then I came to work today I had no windows key
(4,717 Views)
