Disable property function
Good afternoon,
I am using LabVIEW 8.6.1 and I used three booleans in a vi. What I want is: when one of them is on the other two to be disabled, and of course when all are off all to be enabled.
Can someboby help me with  this.
Thank you in advance
Message 1 of 10
(5,893 Views)
Accepted by LW42
Hi thorfano,
where do you have problems?
Use an event structure to react on the value change event. Get the references of all your controls and build an array with the enabled/disabled states. Change the states with the value change event. You can store the states in an array and run through a loop after every event.
Mike
Message 2 of 10
(5,887 Views)
Thanks a lot for the help.
Message 3 of 10
(5,883 Views)
This code should do the trick!  It's simple enough not to have to attach the actual code for it.  At the moment, when the controls are disabled, they're grayed out but still visible.  If you want them to disappear completely when disabled, just remove the three 'multiply by 2' sections and wire the numbers straight to the property nodes.
Message Edited by James Mamakos on 05-11-2009 01:57 PM
Never say "Oops." Always say "Ah, interesting!"
Message 4 of 10
(5,882 Views)
Are you tring to impliment a "Radio Button" style input where only one can be selected at a time?
Try a Radio Button
https://www.ni.com/docs/en-US/bundle/labview/page/creating-a-radio-buttons-control.html
Omar
Message 5 of 10
(5,880 Views)
I may be wrong, but is my simple method not easier than having an array of references within an event structure?
Message 6 of 10
(5,869 Views)
Thanks a lot. It's nice to have alternatives, and Omar thanks for the suggestion, however in this case I would prefer to avoid radio selection style.
Have a nice evening
Message 7 of 10
(5,862 Views)
Hi James,
how flexible is it, if you need 10 or 100 instead of 3 buttons. Smiley Wink
Mike
Message Edited by MikeS81 on 05-11-2009 03:21 PM
Message 8 of 10
(5,858 Views)
What's wrong with having huge radio-button style coding?! 😉
Fair point - i submit to your superiority, Mike! 😛
Message 9 of 10
(5,847 Views)
it's not necessary. For my sake he could mark your post as solution. I only tried to help.
Mike
Message 10 of 10
(5,845 Views)
