Disable front panel controls Programmatically
Here's what I do.  As I said before, you need to create an array of the controls you want to enable/disable.  You can then pass them into this VI.  Notice there is an array of control references as an input.  Just wire up your reference array to that guy and state if you want enabled or not.
Message 11 of 14
(1,622 Views)
Hi pjr1121 and crossrulz,
Thank you very much for great examples, I try these in my program.
Thanks a lot.
Message 12 of 14
(1,612 Views)
Message 13 of 14
(1,007 Views)
You can get all the references of VI programmatically!
Message 14 of 14
(1,003 Views)
