Disable change on the graph scale
I want to lock the scale of a graph on the front panel, which should display the y-scale from 0 to 6.Max_wanted.jpg
So I've disable the autoscale Y-axis. But at the run time I can still change the max tick label manually.Max_unwanted.jpg
How can I lock the tick label on the scale without using the property node?
Thx,
Wilbur
(3,035 Views)
Accepted by wilburwu
You have a property called Editable in the Y scale properties of the graph set that to False.
(3,030 Views)
Surely it works,thanks.
Still I have to write it in the block diagram. But there is no setting of the properties?
(3,013 Views)
