Disable a tab
Dear Experts,
I am attaching the following vi. I want to disable 'page 1' tab when Ok button is pressed. I kindly request you to help me in implementing the same. Thank you.
Message 1 of 11
(4,984 Views)
Accepted by topic author salauddin
Use "Pages" property node which will return an array of page references, index the page you want to change and use "Page Enabled State" property node.
Lucian
CLA
Message 2 of 11
(4,966 Views)
I developed something like this. But, still not getting the desired functionality. Kindly help.
Message 3 of 11
(4,938 Views)
Hi salauddin,
why do you need to read the "pages" property so often (in each iteration)? References do not change at runtime…
Why are there so many hidden wires? How should we analyze your block diagram? (Why don't you attach your VI???)
What is the "expected behaviour"?
There is no "OK button" in your image…
Message 4 of 11
(4,936 Views)
Thank you. I fixed it by the following code
Message 5 of 11
(4,927 Views)
Dear Experts,
I request you to help  me make the first page invisible after clicking the OK button in the first page. Thank you in advance. Herewith, I attach the screenshot and VI here.
Message 6 of 11
(4,901 Views)
Hi salauddin,
to show/hide pages in a tab control you should use the "Visible" property of the pages…
Btw. this will provide a very bad UX!
Message 7 of 11
(4,892 Views)
When you change the active tab, the other tabs are automatically hidden. There is no need to explicitly hide the tab.  Just move the tab selector off-screen so they can't be seen and use menus, buttons or user events to switch tabs programmatically.
aputman
Message 8 of 11
(4,849 Views)
@aputman wrote:
... Just move the tab selector off-screen so they can't be seen and use menus, buttons or user events to switch tabs programmatically.
I would not physically "move" the tab selector off the screen. This is confusing to the developer and the control can actually still be "tabbed" to (using the Tab key; unless that is disabled in the properties). Also if the front panel ever becomes misaligned during development, it's a pain to move it back to 0,0.
Just hide the tabs by deselecting the Tabs item in the Visible Items list (there's also a property node for this). You'll also need to disable tabbing to the control unless you want someone to change the page with the arrow keys (people still use keyboards, you know).
But to aputman's point, just check out this post (from 18 years ago!) about making a wizard-style interface in LabVIEW with tab controls.
_______________________________________________________________
"Computers are useless. They can only give you answers." - Pablo Picasso
Message 9 of 11
(4,828 Views)
Thank you. I was able to finish it using tab properties.
Message 10 of 11
(4,811 Views)
