Disable Knob after click a button
Im beginner and still learn how to use LabView to program. Would any know how to disable the knob after click a button? And also enable back knob after re-click?
Message 1 of 12
(4,804 Views)
Hi bsang,
you should mark your thread as "LabVIEW NXG" as has been said in those pinned messages in the header of the LabVIEW board!
You need to OBEY the DATAFLOW also in LabVIEW NXG: right now you disable the knob in parallel to your loop polling the button - but not "afterwards"…
Set the button to enabled instead of disabled: use a shift register to store the current condition (like a boolean flag) and switch/invert that condition with each click…
(I guess NXG also allows to use an event structure!?)
Message 2 of 12
(4,802 Views)
Hi GerdW,
Thank you for reply my question. I still get no idea the meaning. Would you might to show me the step?
Message 3 of 12
(4,793 Views)
Hi bsang,
I don't have NXG installed, so I cannot open your GVI.
You find an explanation of DATAFLOW in the LabVIEW help!
Message 4 of 12
(4,789 Views)
Hi GerdW,
Oh i see. Thank You for the reference.
As you given DataFlow link, I might not clear understand about Data Flow. Would you might provide example to show how to disable knob after click a button?
Thanks.
Message 5 of 12
(4,762 Views)
Accepted by KnightBS
Hi bsang,
something like this:
Message 6 of 12
(4,759 Views)
Hi GerdW,
Thank you for the solution. I get the idea how to do. Btw the loop might a bit slow response after click Stop button. How can speed up the process time?
Message 7 of 12
(4,754 Views)
Hi bsang,
there is no wait function in your loops visible, so that VI will run as fast as possible.
No need to "speed up" anything here!
(You should think about using event structures to slow down that VI!)
Message 8 of 12
(4,747 Views)
@KnightBS wrote:
Hi GerdW,
You only need one while loop and no case structure.
Message 9 of 12
(4,728 Views)
Hi GerdW,
Thank you for advice and solution. I am glad to learn from you.
Thank You. Have a nice day.
Message 10 of 12
(4,708 Views)
