Disable/Case Structure Implementation Issue
In my block diagram I have 10 VISA input blocks. My goal is to allow the user to input a number of VISA inputs, and to disable the rest. I thought about using a case structure, but it does not allow me to remove or disable an unused VISA input. Is there a way to pass a condition to a disable structure (I know there is a conditional disable structure but I want to do this without creating a project) on the block diagram like could to a case structure?
(4,573 Views)
Show us your code!
It sounds like you should just be using a case structure, but since we can't see what you're doing, it's only a guess.
(blog)
(4,572 Views)
That was my initial plan, however I need this structure to enclose all 10 VISA inputs, and not create new ones for each seperate case. When I try to duplicate these inputs for subdiagrams (I need 11 cases, one with no inputs enabled, then one with only one enabled, then tw enabled etc up to all ten enabled) in the condit ional disable structure, it creates 10 more inputs. Case structures do the same thing. I must disable the unused VISA inputs, if they are enabled and not used I get an error message.
(4,542 Views)
Are all the power meters always present?  If you want to just find the resources available, you can use the VISA Find Resource function to find the available ones.  Since you gave us just a tiny picture and not actual code (read: VI), it's hard to make any recommendations.
Bill
CLD
(Mid-Level minion.)
(4,524 Views)
Can you provide your vi? I see you create an array, so you could just delete the undesired inputs from the array in the case structure.
Question though, if you want say 5 inputs, is it going to be the first 5 inputs or will they be selectable, ie. you want 1,4,5,7,8 vs 1-5?
-Matt
(4,519 Views)
Adding to bill post, use VISA find resource function with proper expression and get the resources array.
- Then populate it to listbox with checkbox https://decibel.ni.com/content/docs/DOC-25000
- After which you get array of selected VISA resources array.
uday
(4,484 Views)
