DirectLogic DL350 CPU and LVDSC
Does anyone know if the DL205 or DL405 objects in the Lookout Protocol Drivers can be used with the DL350 CPU (which unlike other DL3xx CPUs, uses memory mapping similar to the DL250 etc.)
I know I can always fall back on Modbus, but there's an advantage in not having to translate register addresses.
Thanks.
Fading out. " ... J. Arthur Rank on gong."
(2,698 Views)
The driver doesn't support those PLC models. You can definately use Modbus or contact Automation Direct to see if they have a driver for this PLC.
Good Luck
Mike
(2,698 Views)
Well, actual testing with the DL205 driver shows it _does_ work with a DL350 CPU.
(2,698 Views)
