Digital input event handler
Hi-
My labview code needs to execute only when a physical switch is pressed by the user.
Is it possible to generate a DAQmx event for a level change on a digital input line of the USB-6343?
I am using LV2010 on a windows 7 machine.
Best,
Dar Bahatt
(3,926 Views)
Yes it is possible to rise an event for a level change. You can use value signal property node.
(3,919 Views)
Can you give more details?
(3,916 Views)
Hi Dar,
  Please use Value(signalling) property of the indicator...Please see the screen shot.
Srikrishna
(3,913 Views)
Thanks!
In your method do I need to constantly monitor (loop with digital input read) the value of the
digital input associated with the UI indicator? If so, that would use system resources.
If possible, I prefer using a DAQmx event with an event handelr within a while loop. Not sure if
DIO can be set to generate an event.
Dar
(3,900 Views)
Accepted by Dar_Bahatt
Hi Dar,
  If you want to use the daqmx  event for level change,then you have to register events..Please go through this program to begin with..http://zone.ni.com/devzone/cda/epd/p/id/317
Srikrishna.
Srikrishna
(3,885 Views)
