Digital Waveform Graph refuses to edit Bus names
I am trying to display digital waveforms on graph whose lines are grouped. It looks like the functionality exists to group the lines into "Buses". There appears to be a way to rename each Bus from its default "Bus 0, Bus 1, etc." since there is an Express VI called "Group Digital Signals" that does it. It looks like the express VI is editing the attributes on the waveforms in order to rename the Buses. The attributes are NI_ChannelName for the Bus and NI_LineNames for the lines that make up the bus.
When I code it, the Line Names are renamed according to what I want, but the Bus names remain default Bus 0, Bus 1, etc. Is there something I must do to rename the Buses?
(see attached VI)
Dan
(4,374 Views)
So Young Daniel, do you mean like this?
All I did was select where is said Bus 0,1 or 2 and typed in a new value.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,359 Views)
Yes, but shouldn't it work by setting the attribute? I was hoping to be a bit more dynamic.
Thanks Mr. Un-tamed Lion!
(4,342 Views)
Oh, I see what you mean. I'll take another look at it tomorrow.
Mike...
LabVIEW Champion
(4,336 Views)
Accepted by Photon_Dan
So, it works with the good old Property Node. Just set Active Bus and then write Bus.Name.
I was lead to believe that the attributes would work based on the example here.
 - Dan
(4,310 Views)
Actually, I was about to post code using property nodes...
However, the example only shows setting the names of lines. The distinction of a bus desn't exist in that example.
Mike...
LabVIEW Champion
(4,306 Views)
