Digital IO test
Could someone please show/explain how i would get an input port to turn on an indicator in labview. there 8 switches i need to turn on. i'm confused how to convert numeric to true false? I've attached my VI and picture of physical setup
Cheers
(2,929 Views)
Accepted by Terreh
It appears that your "DigitalIn" task is configured to read the entire port. So you will get an 8bit number representing all 8 lines of the port.
You can convert the number to a boolean array and then index out each line.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,897 Views)
Ahh thank you vey much 🙂
(2,883 Views)
