Digital Filter
Hello everyone I am trying to design a IIR Filter but unable to complete it because of two Errors. I am using Labview Community edition. Here is a snippet of it. The errors are "You have connected terminals of different types". Do I have to change properties of Sink or source? The other problem I am facing is I am unable to create a cluster of waveform graph to show magnitude and phase respponse. The ones in the image are just clusters how do i do it? I have also attatched a VI file. It would be great help if anyone answered.
Message 1 of 12
(4,008 Views)
Kindly Save the VI for Previous version of labview.
Message 2 of 12
(4,001 Views)
How do I do that? I don't get what you are saying.
Message 3 of 12
(3,998 Views)
Go to your vi. in that file->Save for previous version.
Choose LabVIEW 12.0 and save and post the vi here.
Message 4 of 12
(3,995 Views)
Here it is for v12.0
Message 5 of 12
(3,973 Views)
I have modified the VI, kindly check if that the thing you wanted or not.
Message 6 of 12
(3,969 Views)
Thank you for trying but the desired output is:
Message 7 of 12
(3,953 Views)
Check this out.
Message 8 of 12
(3,932 Views)
The on block you disabled in the VI should not be disabled. Anyway thanks for trying again and again but I am just looking to connect multiply VI to bundle and unwarp phase VI to bundle and then after bundle to Waveform cluster.
Do you know a way for that.?
Message 9 of 12
(3,905 Views)
The second element of the bundle is initialised using a double value (sampling frequency/1024) then you're trying to write an array of doubles to it from Unwrap Phase.vi.  For the third element, you're trying to write an array of doubles to a cluster.
Message 10 of 12
(3,861 Views)
