Different data type to plot with XY graph, help needed
Hi, I want to build a XY graph using those two data types. But I got an error saying its imcompatible and I dont know how to solve it. Need some help, thank you
Message 1 of 10
(4,555 Views)
Hi jorge,
your two wires use different datatypes so you cannot "join" them.
See the context help of the XY graph to read which datatypes the graph supports…
Message 2 of 10
(4,546 Views)
Yes, but I dont know how to convert to the same data type. Thank you
Message 3 of 10
(4,534 Views)
Accepted by jorgebarreto
Hi Jorge,
then you should learn about using basic functions:
Message 4 of 10
(4,523 Views)
Ok, thank you. If I understand now I have the two data types with the same type but  how do I plot them in XY graph? because I used build array and it's not working, Thank you again
Message 5 of 10
(4,513 Views)
Hi Jorge,
What exactly is not working for you?
No problems for me:
When you have problems with your VI you should attach the VI! (I prefer LV2014.)
Message 6 of 10
(4,506 Views)
I have the data-set from that for loop and "sat-curve" with same data type...I use build array do connect them to build a XY graph, but I cant...
Message 7 of 10
(4,500 Views)
Now is working, I used reshape array, thanks a lot for your help!
Message 8 of 10
(4,493 Views)
Hi Jorge,
you don't need ReshapeArray: simply right-click BuildArray and activate the append mode…
Message 9 of 10
(4,486 Views)
Thanks a lot Gerd.
kind regards
Message 10 of 10
(4,476 Views)
