Difference between running continuously and While loop
Hi All
Is there any Difference between running continuously and While loop apart from Conditional terminal in while loop?
Message 1 of 20
(11,574 Views)
You refer to the "Run Contiously" button in the icon bar?
You shouldn't use that. The issue is that most users press the "Abort" button to stop execution which could be fatal. Not necessarily fatal for humans (but possible) but more on hardware (if used) and at least software data integrity.
So get used to always implement loops in case you need repetative execution.
Norbert
Expert: Geometry
Message 2 of 20
(11,572 Views)
Yes, I am referring to Run Continuously in the icon bar.
I have got the point that it's not recommended to use Run Continuously, but is there any difference in term of execution of the VI.
Message 3 of 20
(11,566 Views)
Things that contain "First call" might not behave the way you expect.
Not sure what differences there are behind the scenes though.
0xDEAD
Message 4 of 20
(11,561 Views)
0xDEAD
There are several ways to specify a number base.  In documents, the most proper way is: "DEAD hexadecimal", or "DEAD hex"; even "DEAD16" is considered acceptable.  In computer programming languages we find things such as:
Ada             16#DEAD#
Assembler   0DEADh
Basic           &hDEAD
C                 0xDEAD
Fortran        Z"DEAD
Pascal        $DEAD
I don't understand why people so often choose an icky way (0x...) to designate hexadecimal in documents.
Message 5 of 20
(11,528 Views)
0xDEAD
Ada             16#DEAD#
Assembler   0DEADh
Basic           &hDEAD
C                 0xDEAD
Fortran        Z"DEAD
Pascal        $DEAD
I would think its probably the most recognised way to denote it.
I will change to $DEAD for now as hark back to the simpler days of the Motorola 6800 assembly. I just hope I don't Halt and Catch Fire.
$DEAD
Message 6 of 20
(11,513 Views)
It's more a question of "habit", both Good and Bad.
  • Run Continuously basically means "Run and never stop".  If you really intend for this to happen (for example, firmware for an instrument that is on 24-7-365), this may be OK, but if you intend for your program to stop, you may want to program a Shutdown routine (close files, stop hardware, dump the Error Log, etc.).
  • Thinking about "how do I safely stop this routine" often leads to better code.
  • If you ever build your program into an Application, you may not have an Abort button, but will also not have a "Run Continuously" button (the program will start running when it is loaded, at least this is my experience).
  • If you want the functionality of Run Continuously, you can always "program it" by enclosing the code in a While Loop and wiring "False" to the Stop terminal.  This has some additional advantages:
    • You can use Shift Registers on the While loop.
    • You can have some "run-once-before" initialization code done outside the While Loop and bringing their results into the Loop.
Message 7 of 20
(11,505 Views)
Accepted by topic author LV_COder
  • "Run continuously" is a misnomer. More accurate would be "restart the VI from scratch whenever it completes all of it's code", but that would not fit on the tip strip. 😄
  • It is a debugging tool, nothing more. I use it to e.g. troubleshoot subVIs that don't have a toplevel loop in standalone mode to quickly test how the outputs change when I twiddle the controls.
  • Any reasonable toplevel code contains initialization, operation, and shutdown parts. Typically only the operational parts belong inside a toplevel loop. You don't want to continuously start over with potentially expensive code that really needs to be done only once.
  • "first call?" will not work right as has already been mentioned. Every call is a first call! :D.
  • Also, any code that uses a feedback node set to "initialize on first call" will work differently under continuous run vs. regular run mode.
  • "Run continuously" will run as fast as the computer allows, redlining at least one CPU core unless there is a wait somewhere (there probably ins't!). This starves other processes and reduces battery life. A toplevel while loop typically has a reasonable wait.
  • A VI running under "run continuosuly" cannot be stopped normally, just aborted. This can be dangerous, e.g. the 100kV source controlled by it may remain turned on, putting people and hardware in danger.
Message 8 of 20
(11,462 Views)
You don't have to abort. You can click the "run continuously" button a second time and the VI finishes normally.
Message 9 of 20
(11,417 Views)
Correct. But most users don't know this and do use ABORT....
Norbert
Expert: Geometry
Message 10 of 20
(11,398 Views)
