Difference between Master/Slave vs Producer/Consumer?
Can any one of point out the Difference between Master/Slave vs Producer/Consumer?
Is producer consumer also a master slave?
Hemant
(8,937 Views)
Accepted by topic author LV_COder
Perhaps overly simplified, but:
Master/Slave: 1 master loop, N slave loops
Producer/Consumer: N producer sources, 1 consumer loop
Master/Slave is usually used for parallel operations to be executed in arbitrary order where Producer/Consumer is used when operations might be requested simultaneously but need to execute in a serial order.
You can see that they are equivalent if and only if N = 1.
(8,925 Views)
Producer consumer, means only one consumer? I am little confuse.
(8,913 Views)
Producer/Consumer - all elements are processed, therefore Queue
Master/Slave - only the latest command is processed, therefore Notifier
A Master/Slave is actually closer to a Queued Message Handler, but that is another thread...
(8,887 Views)
