DeviceNet in Real-Time. Labview
I´m trying to do a program using the NI 9882 module (Crio).
I have carried out with the indications included in the examples: "DeviceNet cRio Basic.lvproj", to compile and load the FPGA bitfile.
In Chassis configuration, I have defined "Labview FPGA Interface", and the initial program to make works the FPGA.
That was easy and the program is running perfectly using the Highlight Execution.
°    My problem is when I´m trying to do it from the Crio module ("Real Time Appplication")--> Run as Startup. The program is not doing anything...and I don´t know which could be the reason..
°    Also I have another problem, because I´ve made the rest of my program using "Scan Interface", but with the FPGA, I need to have the chassis in the "FPGA Interface"mode....will this give me problems?, is it posible to have "Scan" and "FPGA" interfaces working in the same proyect?? How? or for controlling the DeviceNet module I need to reconfigure my complete program for the FPGA configuration.
Thanks so much for your time and support!!
Message 1 of 1
(2,712 Views)
