Determining the max and min range of fxp type for fpga target with FIFO
Used device : USB-7855R
To stream data from FPGA target to Host PC, I used FIFO.
At this time, the configuration option of the FIFO is like to as below
(1) Data type : fxp
(2) Singed
(3) Singed word length : 27 bit
(4) Integer word length : 13 bit
By using option, I obtained the value range of max = 4095 and min -4096.
However, when checking the value of FIFO in the Host PC, only +16 and -16 values are checked.
Why aren't more value being expressed?
(1,015 Views)
This is not clear.  The two sides should be of the same data type.  Can you post code or a screen shot?
ALE Consultants
(961 Views)
I'm sorry.
The wiring in my block diagram was complicated,
so I made a mistake.
Thanks for your interest.
(933 Views)
