Detecting Knob Events
  I am using Labview 8 and I was wondering if there is a quick a dirty way to detect when a user is using and/or  released the mouse key when they are using a knob. The knob is used to set a value of a power supply and I only want to sent out the command to the power supply when the user is
adjusting the know OR when the user has finished adjusting the knob.
  I want to avoid constantly sending the commaond to the power supply when the user is not using the knob. I would like to avoid having a seperate push button that the user has to press when they have finished adjusting the knob.
Have a great day!
Kaspar
Message 1 of 10
(5,250 Views)
This is the perfect situation to use an event structure.  Events can be configured for mouse down, mouse up, value change, etc., all of which I think would suit your application.  If you have any questions about how to use an event structure, don't be afraid to post!
Message 2 of 10
(5,245 Views)
Kaspar,
this is exactly one issue where you would use the event structure. There are many examples available, some of them in the example finder of LV.
hope this helps,
Norbert B.
NI Germany
PS.: i would have linked the help for this structure to the post, but it seems that the server is currently not available Smiley Sad
Norbert
Expert: Geometry
Message 3 of 10
(5,240 Views)
   Thanks for the quick response. I have never used an event structure, do you have examples of using a event structure for a knob?
Kaspar
Message 4 of 10
(5,231 Views)
There's an example called "Event Tracking.vi", which would show you how to use some of the parts that you would use in your application.  Search for that in example finder, and give it a try.
To adapt some of the parts in the Event Tracking.vi to a knob would be really simple.  You could just replace the slider with a knob!
Message 5 of 10
(5,222 Views)
Kaspar,
here is the link i didnt manage to get yesterday. There is no exact example for a knob, but for general buttons and similar. But if you read the help, you will be able to solve the issue in a very short time Smiley Wink
Norbert
Norbert
Expert: Geometry
Message 6 of 10
(5,196 Views)
I am a bit late with my reply but I recently needed something similar;
I wanted to send a valve setting over RS232 to a massflow controller using a front panel with a dial control (0% to 100%). Typically a user clicks the dial and drags it tot the desired value. However, if I would have just used a mouse up event a command wouldalways be sent ifa user cliks the dial without changing the value.
Therefore I combined  a Mouse Up and a Value Change event using an intermediate local variable.
What the attached VI now  does is
1) wait until the user changes the dial setting andreleases the mouse
2) If  this happens do something(send a command or in this case show a dialog)
The only thing I would liketo know is if I could implement an identical behaviour without needing  the boolean control on my UI...
Message 7 of 10
(5,103 Views)
Hi.  Are you just concerned with the aesthetics of the front panel?  If so, you can right click the boolean and select Advanced>>Hide Control.  If that's not what you are looking for, please post back.
Lorielle P.
Applications Engineer
Message 8 of 10
(5,070 Views)
I'd just like to suggest that you attempt to use only the Value Change event on your knob.  Things are usually much simpler if you can avoid having to look at mouse down / mouse up, and it sounds like Value Change is exactly what you want.
Also, to avoid flooding your instrument with commands when the user grabs the knob and drags it around very quickly, you might consider setting the increment value of the knob to a reasonable value for your application, so that every pixel of mouse movement while they've grabbed the knob doesn't cause its value to change.
Good luck!
Message 9 of 10
(5,068 Views)
... Or simply flush stale events by comparing the event value terminal with the actual knob value, then skip computations unless the two values are equal.
See the "selective update" example here: http://forums.ni.com/ni/board/message?board.id=170&message.id=207811#M207811
Message 10 of 10
(5,060 Views)
