Detect unusual changes in graphs
i have a 1 dimensional array and i display it on a graph. The problem here I want to find the anomaly on this chart (because normally the chart will be stable for a while, when there is an outlier it will greatly fluctuate like the video I attached below.
Can anyone give me some advice on how to solve this problem.
thank
link video: https://www.youtube.com/watch?v=ClBmxvXMNWo
Message 1 of 12
(3,859 Views)
Hi Vu,
The question is worded wrongly: you don't find changes "in a chart", but you detect anomalies on your data!
So: you need to define an algorithm to detect those "unusual data", then you can easily filter them.
Some of those "unusual data" look like there was "no data" at all from your DAQ device, so you better try to fix the upstream code where those data is read from DAQ device…
Message 2 of 12
(3,850 Views)
Normally you want to get to the root cause of the anomaly and fix it instead of trying to hide it.
Example - holes in the data:
Wrong: Whenever I see a hole in the data, I will fill it with zeros.
Right: I should discover why there are holes in the data and fix it so there are no longer holes in the data.
Bill
CLD
(Mid-Level minion.)
Message 3 of 12
(3,807 Views)
@GerdW wrote:
Hi Vu,
Sorry my English is not good, so the interpretation is difficult to understand. What I mean here is that my data is displayed on a chart to make it easier for you to observe and find outliers. That anomaly was created by me and i want to detect it in software.
I want to find an algorithm that can find that outlier in real time.
I tried using the function "array max min" to find the 2 largest and smallest values. Then subtract 2 results to find fluctuations but it is correct only when my data is stable.
Message 4 of 12
(3,789 Views)
How to find holes in data? This data hole was created by me and I want to detect them in the software to execute the trigger.
Message 5 of 12
(3,786 Views)
Oh!!!  You're simulating a failure and you want to detect it!  I have to think on this - that was unexpected.  Thank you for the clarification.
Bill
CLD
(Mid-Level minion.)
Message 6 of 12
(3,769 Views)
Hi Vu,
Apart from understanding your approach to this by generating the faulty data on your own:
A simple approach might be to detect for sudden "jumps" in your signal by calculating the derivate and checking for large derivate sample values…
Message 7 of 12
(3,764 Views)
Because my data it's stable in one state. Thank you for your help, I look forward to hearing from you.
Message 8 of 12
(3,739 Views)
@GerdW wrote:
Hi Vu,
can you tell more about calculating the derivate and checking for large derivate sample values
Message 9 of 12
(3,735 Views)
Hi Vu,
Did you learn some basic math at school?
Derivative is defined as dx/dt, so you calculate the difference between one sample and the next, then multiply by your sample rate (which is the same as 1/dt)…
You really ask "how to check for large values"? Ever looked at the comparison functions palette?
Message 10 of 12
(3,726 Views)
