Detect the File path change state (excel)
I need to know how I can detect the path change state of my excel file, to set my counter to zero, if the state changes, I was thinking of an event structure, but I don't know how to use it, is it that there are tracks or example for this kind of problem, thank you to all.
(2,456 Views)
Hi Ayoubas,
Which "excel file"?
What is a "path change state"?
Does the filepath change somehow somewhen in the middle of your file operations? (Why?)
What exactly do you want to achieve?
(2,452 Views)
I want once the file path is changed by the user, at this time I have to detect this change to reset my register to zero, the change of path t is manually writing by the user during recording File,I hope you get the idea
(2,448 Views)
Hi Ayoubas,
Use an event structure with a ValueChange event for that filepath control...
(2,435 Views)
I saw that, but I did not understand how, if you can give me an example I will be grateful thank you🙏
(2,429 Views)
Hi Ayoubas,
Simple like this:
(2,421 Views)
Accepted by Ayoubas01
Using a simple path shift register I was able to solve the problem
thanks to all
(2,309 Views)
