Design Trigger Mechanism to send Commands using Case structures
Hi Vance,
@vanceblake wrote:
Also, I see you are using a different function to conduct the boolean checks before the PtbyPt-Boolean crossing, where would I find it on the palette or what is its name?
I repeat from my previous message:
  • There's an InRangeAndCoerce function to check for a range!
Message 11 of 12
(403 Views)
Hi GerdW,
Sorry that's my bad figured it out yesterday. I also figured out how to implement the Data Queue PtbyPt (much easier than the array method) so thanks for that recommendation. Is there a way for me too suppress the output from the sensor after the write command in the Zero calibration mode is sent. I don't want it showing up on my graph cause it completely skews the data and throws off the scale. Thanks again for your help and patience.
Vance
Message 12 of 12
(397 Views)
