Deployment of C++ DLL to Compact RIO
I'm a C++ developer new to LabVIEW (but living in a world of LabVIEW developers).  We're using some C DLLs in our project (which I'm cross compiling for VxWorks properly) and they show up under the Dependencies folder on the target.  If I manually FTP the dll over and run the project, all works great.  No problem.  What I want to figure out is if there's a way for the dll to automatically get deployed (i.e. copied over to the Compact RIO to the appropriate folder) automatically when I deploy the project.  This seems very trivial, and yet I can't find an option to do this.  I tried using a Build Specification, and it seems to put the proper files in my local directory, but the dll still never gets copied to the Compact RIO.  Am I stuck with manually FTPing files over or is there a more elegant way to do this?
(4,318 Views)
You could write  a pre or post build VI that will ftp the dll for you automatically
(4,261 Views)
I very much appreciate the thought, but don't think writing a vi with hard coded FTP parameters is all that elegant.
(4,243 Views)
Why would they be hard coded constants? You can programmatically extract all the information you would need except for the password if one exists.
(4,231 Views)
Ok that could be a good solution then.  So in the vi I can access the target's IP address and such?
(4,228 Views)
Another approach I have started with for the OpenG ZIP library (that will be present in the next release) is to actually create an installable RT module. That way it will show up in the installation section in MAX when selecting to install custom software to the RT target.
One complication is that the location this module needed to be copied to, is a protected location that requires elevated access rights, so I used Inno Setup to create an installer executable that requires the elevated setup rights when started.
Everything is already present in the SVN repository for the OpenG Toolkit on Sourceforge, so you can go and have a look at it.
Rolf Kalbermatter  My Blog
(4,136 Views)
