Deploy Shared Variables when Application Executes
This is an option in the Project build specification in LV2010.  I am finding that the check mark to signify that I want to include a lvlib in the build and have it auto deploy will not stay check marked.
I have tried to make sure a NSV reference appears in the startup vi and also have tried to 'always include' the library file in the build.  I have attached an image of the dialog in question.  The checked box in the listbox will go away when I close the build window or if I do the build and then reopen the build spec.  This seems like a bug.  Any way around it?
(2,778 Views)
Sachsm,
   Thank you for reporting this unexpected behavior. I have filed a Corrective Action Request #279570 with R&D to be fixed in a future version of LabVIEW.
   Unfortunately the only workaround for now is to only exercise this option right before building (i.e. do not close the window and reopen it to build) the application.
   Again thank you for bringing this to our attention.
Regards from Austin,
Ben J.
(2,754 Views)
Sachsm,
   This issue was fixed with LabVIEW 2010 SP1. Thank you for bringing it to our attention again!
Ben J.
(2,717 Views)
