Deleting a directory
Hi all ,
I'd like to create a .vi that DELETE A DIRECTORY that I select .
I try to use the advanced file functions "delete" but I succeed to delete
just single files .
Thanks .
(3,020 Views)
It only deletes directories that are empty.
Just use "List diretory" first, use the "file names" output array and delete them in a FOR loop, then delete the folder.
(3,020 Views)
Pedrus wrote:
> Hi all ,
> just single files .
There is a gotcha. You have to provide the path to the directory and
make sure that directoy is empty before it will work. Basically this
means a recursive algorithme which isn't to difficult to implement in
LabVIEW if you once know how to do it.
However there is no need to invent the wheel again as on
http://www.openg.org there is the OpenG Toolkit which has in its File
library just that Delete Recursive function.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,020 Views)
