Delete unkown number of characters in a string
hello !
I have this string : <tr><td class='hdr_name'><b>Station ID: </b></td><td class='hdr_value'><b>BT-LED-PUISSANCE</b></td></tr>
(yes it's HTML)
I want to erase all the parts delimited by <>, so in the end i must have ''Station ID: BT-LED-PUISSANCE''
I think i must use a Scan from string but i don't know what to put in the format string. any help ?
Message 1 of 10
(2,408 Views)
How is this related to "signal conditioning" and hardware? (...since you posted here in this forum)
What programming language are you using?
Message 2 of 10
(2,388 Views)
Accepted by topic author Ripers_546
Assuming you are using LabVIEW, here is a solution.
No doubt a RegEx or html specialist will be able to suggest a more effective one.
Message 3 of 10
(2,366 Views)
ok i'm sorry i didn't realy knew where to put this request, and to answer, yes i'm using labview (the community eddition).
after taking the time to test, it works as i wanted thanks you !
Message 4 of 10
(2,356 Views)
(Ah, good to know that this is a LabVIEW question! I have moved this thread to the LabVIEW forum for better visibility.)
The most efficient way is to operate directly on the bytes. Here's one possibility:
(I am sure it can be simplified further)
Message 5 of 10
(2,335 Views)
I'm fairly sure, (under the condition that the Tags are well formated) that ">" Implies a preceding "<"
That and a value changed vim should make the code a bit easier to read.
"Should be" isn't "Is" -Jay
Message 6 of 10
(2,290 Views)
Well, a "!=" (or XOR) toggles the Shift register if the other input is TRUE. That's all we really need. Not sure how you would implement it using the vim and how that would simplify things. 😄
Message 7 of 10
(2,286 Views)
If you want code that's easier to read, here's an alternative. (Still no vim needed). 😄
Message 8 of 10
(2,257 Views)
Learning a little Regex is helpful sometimes.  I can testify to that because I've only learned a little...
Jim
Message 9 of 10
(2,244 Views)
Certainly better than this old suggestion 😄
In my defense, I am sure my code is orders of magnitude faster. 😄 (not tested)
Message 10 of 10
(2,231 Views)
