Delete specific numeric columns from array
How to go about deleting specific numeric columns values from 2D array?
In the attached VI, I would like to delete columns 1, 3 and 4.
Thanks.
(3,662 Views)
Accepted by hiNI
Delete From Array.
Do it in a loop with a shift register.
Start at the highest column number and work down.  Why?  Because if you delete column 1 first, then columns 3 and 4 become 2 and 3 and you'll have to keep track of that.  Start near the end and the columns before that will remain the same numbers.
(3,657 Views)
OpenG has a function to do just that, if you are interested.  Can be installed using VIPM.
aputman
(3,635 Views)
@RavensFan wrote:
Delete From Array.
Of course there are algorithms that are significantly faster. Each delete operation needs to touch (move in memory) every single higher element so after you used Delete from array N times, the highest array elements has been shuffled around N times. This can get very expensive for large arrays and large number of deletions. There are better way as has been discussed many times here.
It is even worse for columns because column elements are not adjacent in memory.
(3,616 Views)
My columns are actually extremely large.  Can you give me an example link to look for a solution to delete the large columns?
Thanks.
(3,598 Views)
