Delete Array
I changed it to split array, which makes more sense based on what you are telling me you want to do.  Reverse the indices so the values are always right.  I also had to disconnect your typedef since you didn't include it.
Is this what you are lookign for?
Message 11 of 19
(2,331 Views)
Sorry but i am not looking for this...
I need different block for 1st 4 elements, then again different block from 5th element till 8th elements...
Now i am getting eights elements when i run loop for 8 number but for that also i need from 8th Elements till 12.
Here Gruop1            Group 2                 Group 3
Element 1               Element 5              Element 9
Element 2               Element 6              Element 10
Element 3               Element 7              Element 11
Element 4               Element 8              Eleme t 12
So at then end i should get like these three groups...
Thanks a lot...
Message 12 of 19
(2,327 Views)
Here it is breaking it into groups.  Also an alternate method if you just specify the group size.
This has some assumptions that you haven't clearly stated:
  1. It assumes that groups are equal size (if not, then you need to process inside of the for loop or pass out group sizes to know to take part of the subarray.
  2. it assumes your groups start at index 0
  3. it assumes you are not trying to remove indices in the middle of the array (i.e. indices 0 to 4, then indices 8 to 12, skipping indices 5-7).
Message 13 of 19
(2,323 Views)
Your assumption number 1 and 2 are correct but the group size for all the gropus may differe it wont be 4 all the time... and number of groups like here i have mention just three so they can also change ...
Thanks a lot..
Message 14 of 19
(2,321 Views)
I cant open ur vi as its version is not 5.1 which i am using....
Message 15 of 19
(2,319 Views)
I didn't say I assumed group size or number of groups.  I said I assumed you are not skipping indicies in the source array.
If you look at the code, you can change the indicies or group size without having to rewrite the code.
Message 16 of 19
(2,318 Views)
Thanks so much... I cant open due to version problem... mine is 7.5.1
Message 17 of 19
(2,315 Views)
Accepted by Sim5
The original VI you posted was in 8.5.  It will take me a little bit to try to save back that far.  But, here are the pics:
Here it is in 8.5.  I accidentally posted the 8.6 version of it.
Message 18 of 19
(2,313 Views)
Sorry in hurry i wrote anything... Its 8.5.1...
Message 19 of 19
(2,310 Views)
