Delay analog output signal generation
Hi all,
Thanks for such a wonderful platform. I have always got some idea to solve my problem here.My problem today is to delay the analog signal generation by certain seconds of time.
I have been generating an analog signal using NI-9263 module on NI-cDAQ 9174 and using a 5v external TTL signal to trigger the same.
I would now like to start the generation. say 5s after I press the trigger.I wonder if this can be achieved.
Looking for some helpful suggestions.
(2,473 Views)
You can do this using the Start.Delay and Start.DelayUnits inputs to the DAQmx Trigger property node.
  • Connect a property node to your DAQmx Task (the default type will read "DAQmx Event").
  • Right-click on the  node and choose "Select DAQmx Class" > "DAQmx Trigger".
  • Choose "Start" > "More" > "Delay" and then optionally drag down to also set "DelayUnits".
  • The default Delay Units is "Sample Clock Periods" - probably you want to set it to "Seconds" using the Create > Constant options.
  • Wire a value to the Delay line on the property node, to set in the appropriate units (i.e. 5 with DelayUnits = Seconds in your example).
GCentral
(2,426 Views)
